[Swift-devel] Re: plan for 0.5 release
    Ben Clifford
    benc at hawaga.org.uk
    Thu Apr  3 01:27:23 CDT 2008
> Can you explain a bit more about the "data channel doesn't work for a bunch of
> sites" problem?
There's some channel reuse code that went into cog in the past few months.
It gets enabled when it detects that it has been pointed at a specific
version of the GridFTP server (which is in itself a bug as it should
really work for lots of versions). The code appears to not work. So when
Swift is pointed at a gridftp server of that version, it cannot stage in
or out files. When it is pointed at a different version gridftp server,
the two bugs cancel each other out - data channel reuse is not used, and
so Swift can stage files in and out.
