[Fwd: Re: [Swift-devel] Re: swift-falkon problem... plots to explain plateaus...]
Ben Clifford
benc at hawaga.org.uk
Tue Apr 1 05:05:46 CDT 2008
On Tue, 1 Apr 2008, Ben Clifford wrote:
> > With this fixed, the total time in wrapper.sh including the app is now about
> > 15 seconds, with 3 being in the app-wrapper itself. The time seems about
> > evenly spread over the several wrapper.sh operations, which is not surprising
> > when 500 wrappers hit NFS all at once.
> Does this machine have a higher (/different) performance shared file
> system such as PVFS or GPFS? We spent some time in november layout out the
> filesystem to be sympathetic to GPFS to help avoid bottlenecks like you
> are seeing here. It would be kinda sad if either it isn't available or you
> aren't using it even though it is available.
>From what I can tell from the web, PVFS and/or GPFS are available on all
of the Argonne Blue Gene machines. Is this true? I don't want to provide
more scalability support for NFS-on-bluegene if it is.
