[Fwd: Re: [Swift-devel] Re: swift-falkon problem... plots to explain plateaus...]
Michael Wilde
wilde at mcs.anl.gov
Tue Apr 1 08:04:04 CDT 2008
We're only working on the BG/P system, and GPFS is the only shared
filesystem there.
GPFS access, however, remains a big scalabiity issue. Frequent small
accesses to GPFS in our measurements really slow down the workflow. We
did a lot of micro-benchmark tests.
Zhao, can you gather a set of these tests into a small suite and post
numbers so the Swift developers can get an understanding of the system's
GPFS access performance?
Also note: the only local filesystem is RAM disk on /tmp or /dev/shm.
(Ioan and Zhao should confirm if they verified that /tmp is on RAM).
- Mike
On 4/1/08 5:05 AM, Ben Clifford wrote:
> On Tue, 1 Apr 2008, Ben Clifford wrote:
>>> With this fixed, the total time in wrapper.sh including the app is now about
>>> 15 seconds, with 3 being in the app-wrapper itself. The time seems about
>>> evenly spread over the several wrapper.sh operations, which is not surprising
>>> when 500 wrappers hit NFS all at once.
>> Does this machine have a higher (/different) performance shared file
>> system such as PVFS or GPFS? We spent some time in november layout out the
>> filesystem to be sympathetic to GPFS to help avoid bottlenecks like you
>> are seeing here. It would be kinda sad if either it isn't available or you
>> aren't using it even though it is available.
>>From what I can tell from the web, PVFS and/or GPFS are available on all
> of the Argonne Blue Gene machines. Is this true? I don't want to provide
> more scalability support for NFS-on-bluegene if it is.
