[Swift-devel] .backup files in SVN and case conflicts (fwd)
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep 21 14:06:07 CDT 2007
Those are fine, you can simply ignore them... I need to get them out of
there, but just hadn't had the time.
You should see the following (placed ... in places where I omitted text)
if everything went OK; note that at the very end, there is (BUILD
SUCCESSFUL, Total time: 45 seconds):
Ioan
iraicu at viper:~/java/svn/falkon> ant all
Buildfile: build.xml
service:
     [exec] compiling the GenericPortal...
     [exec] Buildfile: build-falkon.xml
     [exec] all:
     [exec]       [jar] Building jar:
/home/iraicu/java/svn/falkon/service/org_globus_GenericPortal_common.jar
     [exec]      [copy] Copying 8 files to
/home/iraicu/java/svn/falkon/worker/org
     [exec]      [copy] Copying 38 files to
/home/iraicu/java/svn/falkon/client/org
     [exec] BUILD SUCCESSFUL
     [exec] Total time: 22 seconds
worker:
     [exec] update the stubs...
     [exec] cp: cannot create regular file `./schema/.svn/empty-file':
Permission denied
     [exec] compile common stuff
     [exec] Note: Some input files use or override a deprecated API.
     [exec] Note: Recompile with -deprecation for details.
     [exec] Compiling ClientCreate.java
     [exec] Compiling WorkerRun.java
     [exec] Compiling WorkerRunGram.java
     [exec] Compiling GramClient
client:
     [exec] Compiling Console.java
     [exec] Compiling UserRun.java
all:
BUILD SUCCESSFUL
Veronika Nefedova wrote:
> Ioan, this version is much better!
> I still get some warnings/errors. Could you please let me know if its
> ok to ignore them? These are just a few of those  I got:
> <snip>
> `./org/globus/GenericPortal/common/.svn/format': Permission denied
> `./org/globus/GenericPortal/common/.svn/dir-wcprops': Permission denied
> Note: Recompile with -Xlint:deprecation for details.
> Note: Some input files use unchecked or unsafe operations.
> Note: Recompile with -Xlint:unchecked for details.
> Note:
> org/globus/GenericPortal/clients/GPService_instance/WorkerRunGram.java
> uses unchecked or unsafe operations.
> Note: org/globus/GenericPortal/clients/GPService_instance/UserRun.java
> On Sep 21, 2007, at 1:24 PM, Ben Clifford wrote:
>> incremental updates are a bad habit to get into - don't do that.
>> On Fri, 21 Sep 2007, Ioan Raicu wrote:
>>> OK, it works for me now! If you want to do incremental updates, here
>>> they are:
>>> cd falkon/service/org/globus/GenericPortal/services/core/WS/impl
>>> svn up
>>> cd falkon/service/org/globus/GenericPortal/common
>>> svn up
>>> falkon/service/schema/GenericPortal/GPService_instance
>>> svn up
>>> If not, just do a svn up in the root dir.
>>> Ioan
>>> Ben Clifford wrote:
>>>> I just removed a bunch more backup files - r1253
>>>> Don't forget to 'svn update' in your checkout.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
