[Swift-devel] .backup files in SVN and case conflicts (fwd)
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Sep 21 13:36:45 CDT 2007
Ioan, this version is much better!
I still get some warnings/errors. Could you please let me know if its
ok to ignore them? These are just a few of those  I got:
<snip>
cp: cannot create regular file `./org/globus/GenericPortal/
common/.svn/format': Permission denied
common/.svn/dir-wcprops': Permission denied
compile common stuff
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
Compiling ClientCreate.java
Compiling WorkerRun.java
Compiling WorkerRunGram.java
Note: org/globus/GenericPortal/clients/GPService_instance/
WorkerRunGram.java uses unchecked or unsafe operations.
Compiling GramClient
Compiling Console.java
Compiling UserRun.java
UserRun.java uses unchecked or unsafe operations.
On Sep 21, 2007, at 1:24 PM, Ben Clifford wrote:
> incremental updates are a bad habit to get into - don't do that.
> On Fri, 21 Sep 2007, Ioan Raicu wrote:
>> OK, it works for me now! If you want to do incremental updates,
>> here they are:
>> cd falkon/service/org/globus/GenericPortal/services/core/WS/impl
>> svn up
>> cd falkon/service/org/globus/GenericPortal/common
>> svn up
>> falkon/service/schema/GenericPortal/GPService_instance
>> svn up
>> If not, just do a svn up in the root dir.
>> Ioan
>> Ben Clifford wrote:
>>> I just removed a bunch more backup files - r1253
>>> Don't forget to 'svn update' in your checkout.
