[Swift-devel] .backup files in SVN and case conflicts (fwd)
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Sep 21 14:10:29 CDT 2007
Nope. What I sent you below was the very last stdout I had after the
compile. No 'BUILD SUCCESSFUL" - thus I decided to check with you...
I am at r1256
Nika
On Sep 21, 2007, at 2:06 PM, Ioan Raicu wrote:
> Those are fine, you can simply ignore them... I need to get them
> out of there, but just hadn't had the time.
> You should see the following (placed ... in places where I omitted
> text) if everything went OK; note that at the very end, there is
> (BUILD SUCCESSFUL, Total time: 45 seconds):
> Ioan
> iraicu at viper:~/java/svn/falkon> ant all
> Buildfile: build.xml
> service:
>     [exec] compiling the GenericPortal...
>     [exec] Buildfile: build-falkon.xml
>     [exec] all:
>     [exec]       [jar] Building jar: /home/iraicu/java/svn/falkon/
> service/org_globus_GenericPortal_common.jar
>     [exec]      [copy] Copying 8 files to /home/iraicu/java/svn/
> falkon/worker/org
>     [exec]      [copy] Copying 38 files to /home/iraicu/java/svn/
> falkon/client/org
>     [exec] BUILD SUCCESSFUL
>     [exec] Total time: 22 seconds
> worker:
>     [exec] update the stubs...
>     [exec] cp: cannot create regular file `./schema/.svn/empty-
> file': Permission denied
>     [exec] compile common stuff
>     [exec] Note: Some input files use or override a deprecated API.
>     [exec] Note: Recompile with -deprecation for details.
>     [exec] Compiling ClientCreate.java
>     [exec] Compiling WorkerRun.java
>     [exec] Compiling WorkerRunGram.java
>     [exec] Compiling GramClient
> client:
>     [exec] Compiling Console.java
>     [exec] Compiling UserRun.java
> all:
> BUILD SUCCESSFUL
> Veronika Nefedova wrote:
>> Ioan, this version is much better!
>> I still get some warnings/errors. Could you please let me know if
>> its ok to ignore them? These are just a few of those  I got:
>> <snip>
>> cp: cannot create regular file `./org/globus/GenericPortal/
>> common/.svn/format': Permission denied
>> common/.svn/dir-wcprops': Permission denied
>> Note: Recompile with -Xlint:deprecation for details.
>> Note: Some input files use unchecked or unsafe operations.
>> Note: Recompile with -Xlint:unchecked for details.
>> Note: org/globus/GenericPortal/clients/GPService_instance/
>> WorkerRunGram.java uses unchecked or unsafe operations.
>> UserRun.java uses unchecked or unsafe operations.
>> On Sep 21, 2007, at 1:24 PM, Ben Clifford wrote:
>>> incremental updates are a bad habit to get into - don't do that.
>>> On Fri, 21 Sep 2007, Ioan Raicu wrote:
>>>> OK, it works for me now! If you want to do incremental updates,
>>>> here they are:
>>>> cd falkon/service/org/globus/GenericPortal/services/core/WS/impl
>>>> svn up
>>>> cd falkon/service/org/globus/GenericPortal/common
>>>> svn up
>>>> falkon/service/schema/GenericPortal/GPService_instance
>>>> svn up
>>>> If not, just do a svn up in the root dir.
>>>> Ioan
>>>> Ben Clifford wrote:
>>>>> I just removed a bunch more backup files - r1253
>>>>> Don't forget to 'svn update' in your checkout.
> Ioan Raicu
> Ph.D. Student
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
>       http://dsl.cs.uchicago.edu/
