[Swift-devel] Falcon from SVN doesn't build
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Sep 21 12:26:37 CDT 2007
I'm guessing the stubs are not in the classpath of javac when it builds
that stuff.
On Fri, 2007-09-21 at 12:21 -0500, Ioan Raicu wrote:
> Anyone more familiar with ANT than I am?
> Here is the start of the output from the service compilation for the
> good one:
> > iraicu at viper:~/java/svn/falkon/service> ./clean.gpws.sh
> > Service cleanup complete!
> > iraicu at viper:~/java/svn/falkon/service> ./make.gpws.sh
> > compiling the GenericPortal...
> > Buildfile: build-falkon.xml
> > all:
> >       [jar] Building jar:
> > /home/iraicu/java/svn/falkon/service/org_globus_GenericPortal_common.jar
> >      [copy] Copying 1 file to /home/iraicu/java/svn/falkon/container/lib
> >      [exec] Buildfile: build.xml
> Here is the start of the bad one (why are they different)?
> > genericportal at viper:~/java/svn/falkon/service> ./clean.gpws.sh
> > genericportal at viper:~/java/svn/falkon/service> ./make.gpws.sh
> > all:
> >     [javac] Compiling 22 source files to
> > /home/genericportal/java/svn/falkon/service
> >     [javac]
> > /home/genericportal/java/svn/falkon/service/org/globus/GenericPortal/services/core/WS/impl/ActiveTasks.java:5:
> > package org.globus.GenericPortal.stubs.GPService_instance does not exist
> >     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
> >     [javac] ^
> >     [javac]
> > /home/genericportal/java/svn/falkon/service/org/globus/GenericPortal/services/core/WS/impl/GPResource.java:48:
> Just to rule out any environment variables concern, I copied the good
> install over to the account that doesn't compile with a clean checkout.
> The compile worked just fine in the new account.  I also compared the
> build.xml and build-falkon.xml from the two different falkon installs,
> and they seem identical.
> Any other ideas?
> Ioan
> Ioan Raicu wrote:
> > Let me do a clean checkout and try to compile, and get back to you!
> > BTW, I bet its a classpath problem of some sort, maybe the compile
> > script has somehow been broken...
> > Ioan
> > Veronika Nefedova wrote:
> >> Ioan,
> >> I am trying to build Falcon from SVN now on tg-uc. Unfortunatelly,
> >> the build fails. I have this version of java set in my environment:
> >> java-1.4.2-r1 and this ant : apache-ant-1.6.5-r1
> >> I tried to build it on terminable and it also failed (with
> >> /soft/java-1.5.0_06-sun-r1/bin/java
> >> and /soft/apache-ant-1.6.5-r1/bin/ant )
> >> This is just the very beginning of the output, but there are many
> >> other errors (thats from falcon checkout on terminable)
> >> all:
> >> /autonfs/home/nefedova/falkon/service
> >>     [javac]
> >> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/ActiveTasks.java:5:
> >>     [javac] ^
> >>     [javac]
> >> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/GPResource.java:48:
> >>     [javac] ^
> >> <snip>
> >> Does it build for you? Any suggestions on how make it work?
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu
> Ph.D. Student
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
>        http://dsl.cs.uchicago.edu/
