[Swift-devel] Falcon from SVN doesn't build
Ioan Raicu iraicu at cs.uchicago.edu
Fri Sep 21 12:36:20 CDT 2007
Yeap, that is what it was... but I thought that the stubs were being
generated new each time as part of the service compile... I guess not...
and I'll have to update the compile scripts to do this from now on.  I
am tracking down some other compile problems now, but now there are just
a few of them.
Ioan
Mihael Hategan wrote:
> I'm guessing the stubs are not in the classpath of javac when it builds
> that stuff.
> On Fri, 2007-09-21 at 12:21 -0500, Ioan Raicu wrote:
>> Anyone more familiar with ANT than I am?
>> Here is the start of the output from the service compilation for the
>> good one:
>>> iraicu at viper:~/java/svn/falkon/service> ./clean.gpws.sh
>>> Service cleanup complete!
>>> iraicu at viper:~/java/svn/falkon/service> ./make.gpws.sh
>>> compiling the GenericPortal...
>>> Buildfile: build-falkon.xml
>>> all:
>>>       [jar] Building jar:
>>> /home/iraicu/java/svn/falkon/service/org_globus_GenericPortal_common.jar
>>>      [copy] Copying 1 file to /home/iraicu/java/svn/falkon/container/lib
>>>      [exec] Buildfile: build.xml
>> Here is the start of the bad one (why are they different)?
>>> genericportal at viper:~/java/svn/falkon/service> ./clean.gpws.sh
>>> genericportal at viper:~/java/svn/falkon/service> ./make.gpws.sh
>>> all:
>>>     [javac] Compiling 22 source files to
>>> /home/genericportal/java/svn/falkon/service
>>>     [javac]
>>> /home/genericportal/java/svn/falkon/service/org/globus/GenericPortal/services/core/WS/impl/ActiveTasks.java:5:
>>> package org.globus.GenericPortal.stubs.GPService_instance does not exist
>>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
>>>     [javac] ^
>>>     [javac]
>>> /home/genericportal/java/svn/falkon/service/org/globus/GenericPortal/services/core/WS/impl/GPResource.java:48:
>> Just to rule out any environment variables concern, I copied the good
>> install over to the account that doesn't compile with a clean checkout.
>> The compile worked just fine in the new account.  I also compared the
>> build.xml and build-falkon.xml from the two different falkon installs,
>> and they seem identical.
>> Any other ideas?
>> Ioan
>> Ioan Raicu wrote:
>>> Let me do a clean checkout and try to compile, and get back to you!
>>> BTW, I bet its a classpath problem of some sort, maybe the compile
>>> script has somehow been broken...
>>> Ioan
>>> Veronika Nefedova wrote:
>>>> Ioan,
>>>> I am trying to build Falcon from SVN now on tg-uc. Unfortunatelly,
>>>> the build fails. I have this version of java set in my environment:
>>>> java-1.4.2-r1 and this ant : apache-ant-1.6.5-r1
>>>> I tried to build it on terminable and it also failed (with
>>>> /soft/java-1.5.0_06-sun-r1/bin/java
>>>> and /soft/apache-ant-1.6.5-r1/bin/ant )
>>>> This is just the very beginning of the output, but there are many
>>>> other errors (thats from falcon checkout on terminable)
>>>> all:
>>>> /autonfs/home/nefedova/falkon/service
>>>>     [javac]
>>>> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/ActiveTasks.java:5:
>>>>     [javac] ^
>>>>     [javac]
>>>> /autonfs/home/nefedova/falkon/service/org/globus/GenericPortal/services/core/WS/impl/GPResource.java:48:
>>>>     [javac] ^
>>>> <snip>
>>>> Does it build for you? Any suggestions on how make it work?
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>        http://dsl.cs.uchicago.edu/
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
