[Swift-devel] bug 53
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep 18 10:52:31 CDT 2007
On Mon, 2007-09-17 at 23:50 -0500, Ioan Raicu wrote:
> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
> You might want to set the TCP_PORT_RANGE
It's GLOBUS_TCP_PORT_RANGE. This stuff should go in the docs.
>  (I am not sure this is the
> exact environment variable, but something like that) to be between 50K
> and 60K ports to ensure that GT4 uses one of these open ports.
> Ioan
> Veronika Nefedova wrote:
> > The same. You can check the job's status in its log on viper in
> > ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> > The job is still runnning (i.e. hanging) with the same symptom as
> > before: the first jobs is done and then nothing else gets submitted
> > (the submit host doesn't receive any notification that the job has
> > finished).
> > NIka
> > On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> >> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> >>> I did 'svn up' in cog directory and then did 'ant dist' in the same
> >>> directory.
> >> 'ant dist' should be done in the swift directory.
> >>> My 'svn info' gives me r1740.
> >>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> >>>> Did you update cog?
> >>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> >>>>> No, I've tried with r1740, it still hanged (timed out).
> >>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
> >>>>> loops-20070914-1834-pvhyji75.log
> >>>>> NIka
> >>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> >>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> >>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
> >>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> >>>>>>>>> Ok, so there's something in.
> >>>>>>>> That something was throttling a bit too much (not just jobs,
> >>>>>>>> but all
> >>>>>>>> tasks on that site). I need to take a second look at it.
> >>>>>>> Is that fixed by cog r1740? It looks like that commit is
> >>>>>>> intended to.
> >>>>>> It's an attempt to fix it, but it needs to be confirmed by Nika.
> >>>>>> _______________________________________________
> >>>>>> Swift-devel mailing list
> >>>>>> Swift-devel at ci.uchicago.edu
> >>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
