On Tue, 18 Sep 2007, Mihael Hategan wrote: > On Mon, 2007-09-17 at 23:50 -0500, Ioan Raicu wrote: > > There is a firewall on viper. Ports 50000 - 60000 are open for TCP. > > You might want to set the TCP_PORT_RANGE > > It's GLOBUS_TCP_PORT_RANGE. This stuff should go in the docs. It is in the docs. http://dev.globus.org/wiki/FirewallHowTo --
