[Swift-devel] bug 53
Mihael Hategan hategan at mcs.anl.gov
Tue Sep 18 10:44:04 CDT 2007
On Tue, 2007-09-18 at 10:02 -0500, Veronika Nefedova wrote:
> I set tcp.port.range in swift properties
Not in swift.properties. ~/.globus/cog.properties, or set the env var.
I should add that option to swift.properties, but in the mean time use
one of the above.
>  but even a simple helloworld
> workflow hangs (the  submit host doesn't receive the notification
> from the compute host that the job has finished).
> tcp.port.range=50000,60000
> Not sure what else has changed on viper? It used to be a very good
> submit host, I never had any problems with it );
> Nika
> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
> > Should pick that one. If not ~/.globus/cog.properties ->
> > tcp.port.range=begin,end
> > On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
> >> Not sure if cog picks up the GLOBUS_whatever environment
> >> variables. Mihael
> >> presumably knows.
> >> On Mon, 17 Sep 2007, Ioan Raicu wrote:
> >>> There is a firewall on viper.  Ports 50000 - 60000 are open for
> >>> TCP.  You
> >>> might want to set the TCP_PORT_RANGE (I am not sure this is the
> >>> exact
> >>> environment variable, but something like that) to be between 50K
> >>> and 60K ports
> >>> to ensure that GT4 uses one of these open ports.
> >>> Ioan
> >>>> The same. You can check the job's status in its log on viper in
> >>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> >>>> The job is still runnning (i.e. hanging) with the same symptom
> >>>> as before:
> >>>> the first jobs is done and then nothing else gets submitted (the
> >>>> submit host
> >>>> doesn't receive any notification that the job has finished).
> >>>> NIka
> >>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> >>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> >>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
> >>>>>> same
> >>>>>> directory.
> >>>>> 'ant dist' should be done in the swift directory.
> >>>>>> My 'svn info' gives me r1740.
> >>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> >>>>>>> Did you update cog?
> >>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> >>>>>>>> No, I've tried with r1740, it still hanged (timed out).
> >>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
> >>>>>>>> loops-20070914-1834-pvhyji75.log
> >>>>>>>> NIka
> >>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> >>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> >>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
> >>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> >>>>>>>>>>>> Ok, so there's something in.
> >>>>>>>>>>> That something was throttling a bit too much (not just jobs,
> >>>>>>>>>>> but all
> >>>>>>>>>>> tasks on that site). I need to take a second look at it.
> >>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
> >>>>>>>>>> intended to.
> >>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
> >>>>>>>>> Nika.
> >>>>>>>>> _______________________________________________
> >>>>>>>>> Swift-devel mailing list
> >>>>>>>>> Swift-devel at ci.uchicago.edu
> >>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
