[Swift-devel] bug 53
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep 18 11:50:00 CDT 2007
On Tue, 2007-09-18 at 11:39 -0500, Michael Wilde wrote:
> Did you mean "only for GridFTP"?
yes. sorry.
> See eg:
> http://www.globus.org/mail_archive/discuss/2005/02/msg00115.html
> - Mike
> Mihael Hategan wrote:
> > On Tue, 2007-09-18 at 11:01 -0500, Michael Wilde wrote:
> >> does the cog equivalent of globus_tcp_source_range also need to be set?
> >> is that only for gridftp, or gram as well?  or could this be a gridftp hang?
> > That's only for gram. Yes, it can be set. GLOBUS_TCP_SOURCE_PORT_RANGE.
> >> - mike
> >> Ben Clifford wrote:
> >>> can you submit a job using globus-job-run?
> >>> On Tue, 18 Sep 2007, Veronika Nefedova wrote:
> >>>> I set tcp.port.range in swift properties but even a simple helloworld workflow
> >>>> hangs (the  submit host doesn't receive the notification from the compute host
> >>>> that the job has finished).
> >>>> tcp.port.range=50000,60000
> >>>> Not sure what else has changed on viper? It used to be a very good submit
> >>>> host, I never had any problems with it );
> >>>> Nika
> >>>> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
> >>>>> Should pick that one. If not ~/.globus/cog.properties ->
> >>>>> tcp.port.range=begin,end
> >>>>> On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
> >>>>>> Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
> >>>>>> presumably knows.
> >>>>>> On Mon, 17 Sep 2007, Ioan Raicu wrote:
> >>>>>>> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
> >>>>>>> You
> >>>>>>> might want to set the TCP_PORT_RANGE (I am not sure this is the exact
> >>>>>>> environment variable, but something like that) to be between 50K and 60K
> >>>>>>> ports
> >>>>>>> to ensure that GT4 uses one of these open ports.
> >>>>>>> Ioan
> >>>>>>>> The same. You can check the job's status in its log on viper in
> >>>>>>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> >>>>>>>> The job is still runnning (i.e. hanging) with the same symptom as
> >>>>>>>> before:
> >>>>>>>> the first jobs is done and then nothing else gets submitted (the
> >>>>>>>> submit host
> >>>>>>>> doesn't receive any notification that the job has finished).
> >>>>>>>> NIka
> >>>>>>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> >>>>>>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> >>>>>>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
> >>>>>>>>>> same
> >>>>>>>>>> directory.
> >>>>>>>>> 'ant dist' should be done in the swift directory.
> >>>>>>>>>> My 'svn info' gives me r1740.
> >>>>>>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> >>>>>>>>>>> Did you update cog?
> >>>>>>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> >>>>>>>>>>>> No, I've tried with r1740, it still hanged (timed out).
> >>>>>>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
> >>>>>>>>>>>> loops-20070914-1834-pvhyji75.log
> >>>>>>>>>>>> NIka
> >>>>>>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> >>>>>>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> >>>>>>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
> >>>>>>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> >>>>>>>>>>>>>>>> Ok, so there's something in.
> >>>>>>>>>>>>>>> That something was throttling a bit too much (not just
> >>>>>>>>>>>>>>> jobs,
> >>>>>>>>>>>>>>> but all
> >>>>>>>>>>>>>>> tasks on that site). I need to take a second look at it.
> >>>>>>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
> >>>>>>>>>>>>>> intended to.
> >>>>>>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
> >>>>>>>>>>>>> Nika.
> >>>>>>>>>>>>> _______________________________________________
> >>>>>>>>>>>>> Swift-devel mailing list
> >>>>>>>>>>>>> Swift-devel at ci.uchicago.edu
> >>>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
