[Swift-devel] bug 53
Ben Clifford benc at hawaga.org.uk
Tue Sep 18 10:09:56 CDT 2007
can you submit a job using globus-job-run?
On Tue, 18 Sep 2007, Veronika Nefedova wrote:
> I set tcp.port.range in swift properties but even a simple helloworld workflow
> hangs (the  submit host doesn't receive the notification from the compute host
> that the job has finished).
> tcp.port.range=50000,60000
> Not sure what else has changed on viper? It used to be a very good submit
> host, I never had any problems with it );
> Nika
> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
> > Should pick that one. If not ~/.globus/cog.properties ->
> > tcp.port.range=begin,end
> > On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
> > > Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
> > > presumably knows.
> > > On Mon, 17 Sep 2007, Ioan Raicu wrote:
> > > > There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
> > > > You
> > > > might want to set the TCP_PORT_RANGE (I am not sure this is the exact
> > > > environment variable, but something like that) to be between 50K and 60K
> > > > ports
> > > > to ensure that GT4 uses one of these open ports.
> > > > Ioan
> > > > > The same. You can check the job's status in its log on viper in
> > > > > ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> > > > > The job is still runnning (i.e. hanging) with the same symptom as
> > > > > before:
> > > > > the first jobs is done and then nothing else gets submitted (the
> > > > > submit host
> > > > > doesn't receive any notification that the job has finished).
> > > > > NIka
> > > > > On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> > > > > > On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> > > > > > > I did 'svn up' in cog directory and then did 'ant dist' in the
> > > > > > > same
> > > > > > > directory.
> > > > > > 'ant dist' should be done in the swift directory.
> > > > > > > My 'svn info' gives me r1740.
> > > > > > > On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> > > > > > > > Did you update cog?
> > > > > > > > On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> > > > > > > > > No, I've tried with r1740, it still hanged (timed out).
> > > > > > > > > the log is on viper:/home/nefedova/alamines/MolDyn-244-
> > > > > > > > > loops-20070914-1834-pvhyji75.log
> > > > > > > > > NIka
> > > > > > > > > On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> > > > > > > > > > On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> > > > > > > > > > > On Fri, 14 Sep 2007, Mihael Hategan wrote:
> > > > > > > > > > > > On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> > > > > > > > > > > > > Ok, so there's something in.
> > > > > > > > > > > > That something was throttling a bit too much (not just
> > > > > > > > > > > > jobs,
> > > > > > > > > > > > but all
> > > > > > > > > > > > tasks on that site). I need to take a second look at it.
> > > > > > > > > > > Is that fixed by cog r1740? It looks like that commit is
> > > > > > > > > > > intended to.
> > > > > > > > > > It's an attempt to fix it, but it needs to be confirmed by
> > > > > > > > > > Nika.
> > > > > > > > > > _______________________________________________
> > > > > > > > > > Swift-devel mailing list
> > > > > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
