[Swift-devel] bug 53
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Sep 18 11:01:28 CDT 2007
does the cog equivalent of globus_tcp_source_range also need to be set?
is that only for gridftp, or gram as well?  or could this be a gridftp hang?
- mike
Ben Clifford wrote:
> can you submit a job using globus-job-run?
> On Tue, 18 Sep 2007, Veronika Nefedova wrote:
>> I set tcp.port.range in swift properties but even a simple helloworld workflow
>> hangs (the  submit host doesn't receive the notification from the compute host
>> that the job has finished).
>> tcp.port.range=50000,60000
>> Not sure what else has changed on viper? It used to be a very good submit
>> host, I never had any problems with it );
>> Nika
>> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
>>> Should pick that one. If not ~/.globus/cog.properties ->
>>> tcp.port.range=begin,end
>>> On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
>>>> Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
>>>> presumably knows.
>>>> On Mon, 17 Sep 2007, Ioan Raicu wrote:
>>>>> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
>>>>> You
>>>>> might want to set the TCP_PORT_RANGE (I am not sure this is the exact
>>>>> environment variable, but something like that) to be between 50K and 60K
>>>>> ports
>>>>> to ensure that GT4 uses one of these open ports.
>>>>> Ioan
>>>>>> The same. You can check the job's status in its log on viper in
>>>>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
>>>>>> The job is still runnning (i.e. hanging) with the same symptom as
>>>>>> before:
>>>>>> the first jobs is done and then nothing else gets submitted (the
>>>>>> submit host
>>>>>> doesn't receive any notification that the job has finished).
>>>>>> NIka
>>>>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
>>>>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
>>>>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
>>>>>>>> same
>>>>>>>> directory.
>>>>>>> 'ant dist' should be done in the swift directory.
>>>>>>>> My 'svn info' gives me r1740.
>>>>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
>>>>>>>>> Did you update cog?
>>>>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
>>>>>>>>>> No, I've tried with r1740, it still hanged (timed out).
>>>>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
>>>>>>>>>> loops-20070914-1834-pvhyji75.log
>>>>>>>>>> NIka
>>>>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
>>>>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
>>>>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
>>>>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
>>>>>>>>>>>>>> Ok, so there's something in.
>>>>>>>>>>>>> That something was throttling a bit too much (not just
>>>>>>>>>>>>> jobs,
>>>>>>>>>>>>> but all
>>>>>>>>>>>>> tasks on that site). I need to take a second look at it.
>>>>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
>>>>>>>>>>>> intended to.
>>>>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
>>>>>>>>>>> Nika.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
