[Swift-devel] bug 53
Veronika Nefedova nefedova at mcs.anl.gov
Tue Sep 18 10:02:11 CDT 2007
I set tcp.port.range in swift properties but even a simple helloworld
workflow hangs (the  submit host doesn't receive the notification
from the compute host that the job has finished).
tcp.port.range=50000,60000
Not sure what else has changed on viper? It used to be a very good
submit host, I never had any problems with it );
Nika
On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
> Should pick that one. If not ~/.globus/cog.properties ->
> tcp.port.range=begin,end
> On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
>> Not sure if cog picks up the GLOBUS_whatever environment
>> variables. Mihael
>> presumably knows.
>> On Mon, 17 Sep 2007, Ioan Raicu wrote:
>>> There is a firewall on viper.  Ports 50000 - 60000 are open for
>>> TCP.  You
>>> might want to set the TCP_PORT_RANGE (I am not sure this is the
>>> exact
>>> environment variable, but something like that) to be between 50K
>>> and 60K ports
>>> to ensure that GT4 uses one of these open ports.
>>> Ioan
>>> Veronika Nefedova wrote:
>>>> The same. You can check the job's status in its log on viper in
>>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
>>>> The job is still runnning (i.e. hanging) with the same symptom
>>>> as before:
>>>> the first jobs is done and then nothing else gets submitted (the
>>>> submit host
>>>> doesn't receive any notification that the job has finished).
>>>> NIka
>>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
>>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
>>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
>>>>>> same
>>>>>> directory.
>>>>> 'ant dist' should be done in the swift directory.
>>>>>> My 'svn info' gives me r1740.
>>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
>>>>>>> Did you update cog?
>>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
>>>>>>>> No, I've tried with r1740, it still hanged (timed out).
>>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
>>>>>>>> loops-20070914-1834-pvhyji75.log
>>>>>>>> NIka
>>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
>>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
>>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
>>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
>>>>>>>>>>>> Ok, so there's something in.
>>>>>>>>>>> That something was throttling a bit too much (not just jobs,
>>>>>>>>>>> but all
>>>>>>>>>>> tasks on that site). I need to take a second look at it.
>>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
>>>>>>>>>> intended to.
>>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
>>>>>>>>> Nika.
>>>>>>>>> _______________________________________________
>>>>>>>>> Swift-devel mailing list
>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
