[Swift-devel] bug 53
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Sep 17 23:50:47 CDT 2007
There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
You might want to set the TCP_PORT_RANGE (I am not sure this is the
exact environment variable, but something like that) to be between 50K
and 60K ports to ensure that GT4 uses one of these open ports.
Ioan
Veronika Nefedova wrote:
> The same. You can check the job's status in its log on viper in
> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> The job is still runnning (i.e. hanging) with the same symptom as
> before: the first jobs is done and then nothing else gets submitted
> (the submit host doesn't receive any notification that the job has
> finished).
> NIka
> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
>>> I did 'svn up' in cog directory and then did 'ant dist' in the same
>>> directory.
>> 'ant dist' should be done in the swift directory.
>>> My 'svn info' gives me r1740.
>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
>>>> Did you update cog?
>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
>>>>> No, I've tried with r1740, it still hanged (timed out).
>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
>>>>> loops-20070914-1834-pvhyji75.log
>>>>> NIka
>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
>>>>>>>>> Ok, so there's something in.
>>>>>>>> That something was throttling a bit too much (not just jobs,
>>>>>>>> but all
>>>>>>>> tasks on that site). I need to take a second look at it.
>>>>>>> Is that fixed by cog r1740? It looks like that commit is
>>>>>>> intended to.
>>>>>> It's an attempt to fix it, but it needs to be confirmed by Nika.
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
