[Swift-devel] bug 53
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Mon Sep 17 14:07:04 CDT 2007
The same. You can check the job's status in its log on viper in
~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
The job is still runnning (i.e. hanging) with the same symptom as
before: the first jobs is done and then nothing else gets submitted
(the submit host doesn't receive any notification that the job has
finished).
NIka
On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
>> I did 'svn up' in cog directory and then did 'ant dist' in the same
>> directory.
> 'ant dist' should be done in the swift directory.
>> My 'svn info' gives me r1740.
>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
>>> Did you update cog?
>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
>>>> No, I've tried with r1740, it still hanged (timed out).
>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
>>>> loops-20070914-1834-pvhyji75.log
>>>> NIka
>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
>>>>>>>> Ok, so there's something in.
>>>>>>> That something was throttling a bit too much (not just jobs,
>>>>>>> but all
>>>>>>> tasks on that site). I need to take a second look at it.
>>>>>> Is that fixed by cog r1740? It looks like that commit is
>>>>>> intended to.
>>>>> It's an attempt to fix it, but it needs to be confirmed by Nika.
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
