[Swift-devel] bug 53
    Ben Clifford
    benc at hawaga.org.uk
    Tue Sep 18 02:42:57 CDT 2007
Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
presumably knows.
On Mon, 17 Sep 2007, Ioan Raicu wrote:
> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.  You
> might want to set the TCP_PORT_RANGE (I am not sure this is the exact
> environment variable, but something like that) to be between 50K and 60K ports
> to ensure that GT4 uses one of these open ports.
> Ioan
> Veronika Nefedova wrote:
> > The same. You can check the job's status in its log on viper in
> > ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> > The job is still runnning (i.e. hanging) with the same symptom as before:
> > the first jobs is done and then nothing else gets submitted (the submit host
> > doesn't receive any notification that the job has finished).
> > NIka
> > On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> > > On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> > > > I did 'svn up' in cog directory and then did 'ant dist' in the same
> > > > directory.
> > > 'ant dist' should be done in the swift directory.
> > > > My 'svn info' gives me r1740.
> > > > On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> > > > > Did you update cog?
> > > > > On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> > > > > > No, I've tried with r1740, it still hanged (timed out).
> > > > > > the log is on viper:/home/nefedova/alamines/MolDyn-244-
> > > > > > loops-20070914-1834-pvhyji75.log
> > > > > > NIka
> > > > > > On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> > > > > > > On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> > > > > > > > On Fri, 14 Sep 2007, Mihael Hategan wrote:
> > > > > > > > > On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> > > > > > > > > > Ok, so there's something in.
> > > > > > > > > That something was throttling a bit too much (not just jobs,
> > > > > > > > > but all
> > > > > > > > > tasks on that site). I need to take a second look at it.
> > > > > > > > Is that fixed by cog r1740? It looks like that commit is
> > > > > > > > intended to.
> > > > > > > It's an attempt to fix it, but it needs to be confirmed by Nika.
> > > > > > > _______________________________________________
> > > > > > > Swift-devel mailing list
> > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
