[Swift-devel] Kickstart under Falkon
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Sep  7 16:39:00 CDT 2007
Nice.  I asked because I didnt see it there - turns out I had the same
rev of the users guide in a browser window for the past week or so. Its
great to see progress being made and especially the docs steadily improving!
Ben Clifford wrote:
> I added a link in here a couple days ago:
> http://www.ci.uchicago.edu/swift/guides/userguide.php#kickstart
> On Fri, 7 Sep 2007, Michael Wilde wrote:
>> Cool - I'll try it.
>> Does anyone have a set of compiled kickstart binaries (I'll start on the UC
>> teragrid so I'll need IA64 and i686).
>> Any issues of which VDS release I pull these from?
>> Any sugestions on how to package this for users?
>> Ben Clifford wrote:
>>> in theory, kickstart should work through any of the execution providers, be
>>> it local, gram, falkon, whatever. if it doesn't, paste what's happening
>>> here.
>>> you shouldn't need to do anything falkon specific. turning on kickstart
>>> changes the command that the swift runtime passes to the execution system
>>> (i.e. fork, gram, falkon) which should run it in the same way it runs
>>> anything else.
>>>> Ioan, can you remind me - is kickstart supported under Falkon?
>>>> If so - just turn on the properties and it should work?
>>>> If not - any ideas on whats needed?
>>>> - Mike
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
