[Swift-devel] Re: Kickstart under Falkon
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep  7 16:31:52 CDT 2007
Kickstart should be transparent to Falkon.  Enable it as you would
normally enable it, and things should work as they would over GRAM or
other LRMs.  I have not personally tried it, but my understanding is
that kickstart should work by simply enabling it (and having it
installed off course)!
Michael Wilde wrote:
> Ioan, can you remind me - is kickstart supported under Falkon?
> If so - just turn on the properties and it should work?
> If not - any ideas on whats needed?
> - Mike
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
