[Swift-devel] Kickstart under Falkon
Ben Clifford
benc at hawaga.org.uk
Fri Sep 7 16:20:50 CDT 2007
I added a link in here a couple days ago:
http://www.ci.uchicago.edu/swift/guides/userguide.php#kickstart
On Fri, 7 Sep 2007, Michael Wilde wrote:
> Cool - I'll try it.
> Does anyone have a set of compiled kickstart binaries (I'll start on the UC
> teragrid so I'll need IA64 and i686).
> Any issues of which VDS release I pull these from?
> Any sugestions on how to package this for users?
> Ben Clifford wrote:
> > in theory, kickstart should work through any of the execution providers, be
> > it local, gram, falkon, whatever. if it doesn't, paste what's happening
> > here.
> > you shouldn't need to do anything falkon specific. turning on kickstart
> > changes the command that the swift runtime passes to the execution system
> > (i.e. fork, gram, falkon) which should run it in the same way it runs
> > anything else.
> > > Ioan, can you remind me - is kickstart supported under Falkon?
> > > If so - just turn on the properties and it should work?
> > > If not - any ideas on whats needed?
> > > - Mike
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
