[Swift-devel] Kickstart under Falkon
Michael Wilde
wilde at mcs.anl.gov
Fri Sep 7 16:18:32 CDT 2007
Cool - I'll try it.
Does anyone have a set of compiled kickstart binaries (I'll start on the
UC teragrid so I'll need IA64 and i686).
Any issues of which VDS release I pull these from?
Any sugestions on how to package this for users?
Ben Clifford wrote:
> in theory, kickstart should work through any of the execution providers,
> be it local, gram, falkon, whatever. if it doesn't, paste what's happening
> here.
> you shouldn't need to do anything falkon specific. turning on kickstart
> changes the command that the swift runtime passes to the execution system
> (i.e. fork, gram, falkon) which should run it in the same way it runs
> anything else.
> On Fri, 7 Sep 2007, Michael Wilde wrote:
>> Ioan, can you remind me - is kickstart supported under Falkon?
>> If so - just turn on the properties and it should work?
>> If not - any ideas on whats needed?
>> - Mike
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
