[Swift-devel] Kickstart under Falkon
Ben Clifford benc at hawaga.org.uk
Fri Sep 7 15:58:44 CDT 2007
in theory, kickstart should work through any of the execution providers,
be it local, gram, falkon, whatever. if it doesn't, paste what's happening
here.
you shouldn't need to do anything falkon specific. turning on kickstart
changes the command that the swift runtime passes to the execution system
(i.e. fork, gram, falkon) which should run it in the same way it runs
anything else.
On Fri, 7 Sep 2007, Michael Wilde wrote:
> Ioan, can you remind me - is kickstart supported under Falkon?
> If so - just turn on the properties and it should work?
> If not - any ideas on whats needed?
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
