On Mon, 29 Oct 2007, Michael Wilde wrote: > Should Andrew re-run a few good-sized workflows to generate info/ dirs with > timestamps, so we can zero in on the operation(s) that are taking the most > time? A workflow of the size that was showing the suspect symptoms before would be good. --
