[Swift-devel] wrapper.sh logging
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Oct 29 08:38:44 CDT 2007
Sounds great.
Should Andrew re-run a few good-sized workflows to generate info/ dirs
with timestamps, so we can zero in on the operation(s) that are taking
the most time?
On 10/29/07 7:56 AM, Ben Clifford wrote:
> As of r1406, there's a new config option 'sitedir.keep' which defaults
> to false (preserving existing behaviour).
> If this option is set to true, then swift will not clean up the site
> working directory at the end of a workflow. This will leave info/ records
> in place rather than deleting them.
> The info records now contain timestamps and state information, and the
> log-processing code contains some more stuff to graph that information.
