[Swift-devel] Clustering and Temp Dirs with Swift
Michael Wilde
wilde at mcs.anl.gov
Sun Oct 28 18:12:53 CDT 2007
OK. You two should decide.
I observe that if we use the current strategy to pick a unique wfid,
then we dont need a global lock, just a strategy that works within a
workflow and its top-level client and server-side directories.
Much more important is that we solve the scalability problems, starting
as far as I can tell with the big-dir problems.
Any way you solve it that gets things running fastest soonest, is fine
by me.
Solve away.
- Mike
On 10/28/07 5:57 PM, Ben Clifford wrote:
> any sequential numbering relies on having a global lock on a sequence
> counter.
> if we're expecting workflow log names to be unique amongst all workflow
> runs ever (which I believe to be desirable) then there needs to be a
> global shared counter variable between all instances of swift running
> anywhere. that's lame.
> having a large value space and picking numbers in there very sparsely (eg
> timestamp + some random ID) is very scalable in this situation.
