[Swift-devel] excessive rate throttling for	apparently	temporally-restricted failures
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Sun Oct 28 11:23:41 CDT 2007
I mentioned 2 throttling mechanisms, one is to have X outstanding jobs
at any given time (limits jobs in the queue), and Y jobs/sec
submit rate (limits the rate of submission).  I believe both of these
throttling mechanisms could exist without computing site scores,
assuming the user knows what to set X and Y to.
Ioan
Mihael Hategan wrote:
> On Sun, 2007-10-28 at 10:25 -0500, Ioan Raicu wrote:
>> Assuming you have a single site to submit to, then I don't see why you
>> don't want to disable the site scoring altogether?
> Because having too many jobs on that one site may still cause problems.
> That said, the algorithm currently there needs some work.
>>   Of course you still want throttling, but that is more on the level
>> of X outstanding jobs at any given time (and possibly Y jobs/sec
>> submit rate), so you don't overrun the LRM, but you would not want to
>> lower X to some low value just because some jobs are failing.  Again,
>> once you go to multi-site runs, you need the site scoring to decide
>> among the different sites, but with a single site, I see no drawbacks
>> to disabling the site scoring mechanism.
>> Ioan
>> Ben Clifford wrote:
>>> On Sun, 28 Oct 2007, Ioan Raicu wrote:
>>>> they were due to the stale NFS handle error.  I think Mihael outlined in an
>>>> email a while back how to disable the task submission throttling due to a bad
>>>> score, assuming that you have a single site to submit to anyways.
>>> I know how to disable it. I don't particularly want it running rate free.
>>> Whats happening here is that the feedback loop feeding back too much / too
>>> fast for the situation I experience.
>>> There's plenty of fun to be had experimenting there; and I suspect there
>>> will be no One True Rate Controller.
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>        http://dsl.cs.uchicago.edu/
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20071028/033eab95/attachment.html>
