[Swift-devel] excessive rate throttling for apparently temporally-restricted failures
Mihael Hategan
hategan at mcs.anl.gov
Sun Oct 28 14:51:31 CDT 2007
On Sun, 2007-10-28 at 11:23 -0500, Ioan Raicu wrote:
> I mentioned 2 throttling mechanisms, one is to have X outstanding jobs
> at any given time (limits jobs in the queue), and Y jobs/sec
> submit rate (limits the rate of submission). I believe both of these
> throttling mechanisms could exist without computing site scores,
> assuming the user knows what to set X and Y to.
They do exist, but they don't deal with asymmetries between sites. Nor
do they deal with changing situations.
> Ioan
> Mihael Hategan wrote:
> > On Sun, 2007-10-28 at 10:25 -0500, Ioan Raicu wrote:
> > > Assuming you have a single site to submit to, then I don't see why you
> > > don't want to disable the site scoring altogether?
> > Because having too many jobs on that one site may still cause problems.
> > That said, the algorithm currently there needs some work.
> > > Of course you still want throttling, but that is more on the level
> > > of X outstanding jobs at any given time (and possibly Y jobs/sec
> > > submit rate), so you don't overrun the LRM, but you would not want to
> > > lower X to some low value just because some jobs are failing. Again,
> > > once you go to multi-site runs, you need the site scoring to decide
> > > among the different sites, but with a single site, I see no drawbacks
> > > to disabling the site scoring mechanism.
> > > Ioan
> > > Ben Clifford wrote:
> > > > On Sun, 28 Oct 2007, Ioan Raicu wrote:
> > > > > they were due to the stale NFS handle error. I think Mihael outlined in an
> > > > > email a while back how to disable the task submission throttling due to a bad
> > > > > score, assuming that you have a single site to submit to anyways.
> > > > I know how to disable it. I don't particularly want it running rate free.
> > > > Whats happening here is that the feedback loop feeding back too much / too
> > > > fast for the situation I experience.
> > > > There's plenty of fun to be had experimenting there; and I suspect there
> > > > will be no One True Rate Controller.
> > > Ioan Raicu
> > > Ph.D. Student
> > > Distributed Systems Laboratory
> > > Computer Science Department
> > > University of Chicago
> > > 1100 E. 58th Street, Ryerson Hall
> > > Chicago, IL 60637
> > > Email: iraicu at cs.uchicago.edu
> > > Web: http://www.cs.uchicago.edu/~iraicu
> > > http://dsl.cs.uchicago.edu/
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu
> Ph.D. Student
> Chicago, IL 60637
