[Swift-devel] excessive rate throttling for apparently	temporally-restricted failures
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Oct 28 11:15:46 CDT 2007
On Sun, 2007-10-28 at 10:25 -0500, Ioan Raicu wrote:
> Assuming you have a single site to submit to, then I don't see why you
> don't want to disable the site scoring altogether?
Because having too many jobs on that one site may still cause problems.
That said, the algorithm currently there needs some work.
>   Of course you still want throttling, but that is more on the level
> of X outstanding jobs at any given time (and possibly Y jobs/sec
> submit rate), so you don't overrun the LRM, but you would not want to
> lower X to some low value just because some jobs are failing.  Again,
> once you go to multi-site runs, you need the site scoring to decide
> among the different sites, but with a single site, I see no drawbacks
> to disabling the site scoring mechanism.
> Ioan
> Ben Clifford wrote:
> > On Sun, 28 Oct 2007, Ioan Raicu wrote:
> > > they were due to the stale NFS handle error.  I think Mihael outlined in an
> > > email a while back how to disable the task submission throttling due to a bad
> > > score, assuming that you have a single site to submit to anyways.
> > I know how to disable it. I don't particularly want it running rate free.
> > Whats happening here is that the feedback loop feeding back too much / too
> > fast for the situation I experience.
> > There's plenty of fun to be had experimenting there; and I suspect there
> > will be no One True Rate Controller.
> Ioan Raicu
> Ph.D. Student
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
>        http://dsl.cs.uchicago.edu/
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
