[Swift-devel] Loging still messed up after Falkon provider installed
Michael Wilde wilde at mcs.anl.gov
Tue Oct 23 14:48:47 CDT 2007
Yes, there is now :) bug 108.
On 10/23/07 2:25 PM, Mihael Hategan wrote:
> On Tue, 2007-10-23 at 14:07 -0500, Michael Wilde wrote:
>> I installed the deef provider per the instructions in the Falkon SVN
>> root, and my swift .log file is no longer produced.
>> There was much discussion on this on the lists; was it never fixed, or
>> did it break again?
> Never fixed, I'm guessing. Is there a bug report?
>> My non-working log4j.properties file - what I had after installing the
>> deef provider - is below.
>> Below that is what I added from one of Mihael's suggestions in a thread
>> with Jing, which didnt solve the problem till I added back in all the
>> lines that came with the default Swift build (r1339)
>> Is this my error somewhere in setting up Falkon, or is the Falkon
>> provider install messing this up?
>> - Mike
>> ----- Broken config after deef provider installed:
>> #Root category
>> log4j.rootCategory=WARN, CONSOLE
>> # CONSOLE is set to be a ConsoleAppender using a PatternLayout
>> # The class is not printed
>> log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
>> log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
>> log4j.appender.CONSOLE.layout.ConversionPattern=%-5p %x - %m%n
>> # CONSOLE-C is the same as above, but the class is printed
>> log4j.appender.CONSOLE-C=org.apache.log4j.ConsoleAppender
>> log4j.appender.CONSOLE-C.layout=org.apache.log4j.PatternLayout
>> log4j.appender.CONSOLE-C.layout.ConversionPattern=%-5p [%c] %x - %m%n
>> # %provider-deef%
>>          log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
>> log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
>> # %abstraction%
>>          log4j.logger.org.globus.cog.abstraction=WARN
>> # %abstraction-common%
>>          log4j.logger.org.globus.cog.abstraction.impl.common=WARN
>> # %jglobus%
>> # %util%
>> # %provider-gt2%
>> # %provider-gt2ft%
>> # %provider-gt4_0_0%
>> # %provider-condor%
>> # %provider-ssh%
>> # %provider-webdav%
>> # %provider-local%
>> ---- logging works when I add the following lines:
>> log4j.logger.org.globus.cog.abstraction=DEBUG
>> # ^^ Added by Mike per Mihael
>> log4j.rootCategory=WARN, CONSOLE, FILE
>> log4j.appender.CONSOLE.Threshold=WARN
>> log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
>> log4j.appender.FILE=org.apache.log4j.FileAppender
>> log4j.appender.FILE.File=swift.log
>> log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
>> log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
>> HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
>> log4j.logger.swift=DEBUG
>> log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
>> log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
>> log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
>> log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
>> log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
>> log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
