[Swift-devel] [Bug 108] New: Installing deef provider damages log4j config
bugzilla-daemon at mcs.anl.gov bugzilla-daemon at mcs.anl.gov
Tue Oct 23 14:47:49 CDT 2007
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=108
           Summary: Installing deef provider damages log4j config
           Product: Swift
           Version: unspecified
          Platform: All
        OS/Version: Mac OS
            Status: NEW
          Severity: normal
          Priority: P2
         Component: SwiftScript language
        AssignedTo: hategan at mcs.anl.gov
        ReportedBy: wilde at mcs.anl.gov
                CC: hategan at mcs.anl.gov
I installed the deef provider per the instructions in the Falkon SVN root, and
my swift .log file is no longer produced.
There was much discussion on this on the lists; was it never fixed, or did it
break again?
My non-working log4j.properties file - what I had after installing the deef
provider - is below.
Below that is what I added from one of Mihael's suggestions in a thread with
Jing, which didnt solve the problem till I added back in all the lines that
came with the default Swift build (r1339)
Is this my error somewhere in setting up Falkon, or is the Falkon provider
install messing this up?
- Mike
----- Broken config after deef provider installed:
#Root category
log4j.rootCategory=WARN, CONSOLE
# CONSOLE is set to be a ConsoleAppender using a PatternLayout
# The class is not printed
log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
log4j.appender.CONSOLE.layout.ConversionPattern=%-5p %x - %m%n
# CONSOLE-C is the same as above, but the class is printed
log4j.appender.CONSOLE-C=org.apache.log4j.ConsoleAppender
log4j.appender.CONSOLE-C.layout=org.apache.log4j.PatternLayout
log4j.appender.CONSOLE-C.layout.ConversionPattern=%-5p [%c] %x - %m%n
# %provider-deef%
        log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
# %abstraction%
        log4j.logger.org.globus.cog.abstraction=WARN
# %abstraction-common%
        log4j.logger.org.globus.cog.abstraction.impl.common=WARN
# %jglobus%
# %util%
# %provider-gt2%
# %provider-gt2ft%
# %provider-gt4_0_0%
# %provider-condor%
# %provider-ssh%
# %provider-webdav%
# %provider-local%
---- logging works when I add the following lines:
log4j.logger.org.globus.cog.abstraction=DEBUG
# ^^ Added by Mike per Mihael
log4j.rootCategory=WARN, CONSOLE, FILE
log4j.appender.CONSOLE.Threshold=WARN
log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
log4j.appender.FILE=org.apache.log4j.FileAppender
log4j.appender.FILE.File=swift.log
log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
log4j.logger.swift=DEBUG
log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You reported the bug, or are watching the reporter.
