[Swift-devel] Loging still messed up after Falkon provider installed
Mihael Hategan hategan at mcs.anl.gov
Tue Oct 23 14:25:45 CDT 2007
On Tue, 2007-10-23 at 14:07 -0500, Michael Wilde wrote:
> I installed the deef provider per the instructions in the Falkon SVN
> root, and my swift .log file is no longer produced.
> There was much discussion on this on the lists; was it never fixed, or
> did it break again?
Never fixed, I'm guessing. Is there a bug report?
> My non-working log4j.properties file - what I had after installing the
> deef provider - is below.
> Below that is what I added from one of Mihael's suggestions in a thread
> with Jing, which didnt solve the problem till I added back in all the
> lines that came with the default Swift build (r1339)
> Is this my error somewhere in setting up Falkon, or is the Falkon
> provider install messing this up?
> - Mike
> ----- Broken config after deef provider installed:
> #Root category
> log4j.rootCategory=WARN, CONSOLE
> # CONSOLE is set to be a ConsoleAppender using a PatternLayout
> # The class is not printed
> log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
> log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
> log4j.appender.CONSOLE.layout.ConversionPattern=%-5p %x - %m%n
> # CONSOLE-C is the same as above, but the class is printed
> log4j.appender.CONSOLE-C=org.apache.log4j.ConsoleAppender
> log4j.appender.CONSOLE-C.layout=org.apache.log4j.PatternLayout
> log4j.appender.CONSOLE-C.layout.ConversionPattern=%-5p [%c] %x - %m%n
> # %provider-deef%
>          log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
> log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
> # %abstraction%
>          log4j.logger.org.globus.cog.abstraction=WARN
> # %abstraction-common%
>          log4j.logger.org.globus.cog.abstraction.impl.common=WARN
> # %jglobus%
> # %util%
> # %provider-gt2%
> # %provider-gt2ft%
> # %provider-gt4_0_0%
> # %provider-condor%
> # %provider-ssh%
> # %provider-webdav%
> # %provider-local%
> ---- logging works when I add the following lines:
> log4j.logger.org.globus.cog.abstraction=DEBUG
> # ^^ Added by Mike per Mihael
> log4j.rootCategory=WARN, CONSOLE, FILE
> log4j.appender.CONSOLE.Threshold=WARN
> log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
> log4j.appender.FILE=org.apache.log4j.FileAppender
> log4j.appender.FILE.File=swift.log
> log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
> log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
> HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
> log4j.logger.swift=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
> log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
> log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
> log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
