[Swift-devel] Grid Identity Mapping
andrewj at uchicago.edu andrewj at uchicago.edu
Fri Oct 12 14:31:01 CDT 2007
Hello folks,
  I think I need to be mapped or whatever it is called to
Teraport.
Is this true?
Andrew
See below.
Execution failed:
        Could not initialize shared directory on teraport
Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException:
Error communicating with the GridFTP server
Caused by:
        Server refused performing the request. Custom message:
Bad password. (error code 1) [Nested exception message:
Custom message: Unexpected reply: 530-Login incorrect. :
gridmap.c:globus_gss_assist_map_and_authorize:1910:
530-Error invoking callout
530-globus_callout.c:globus_callout_handle_call_type:727:
530-The callout returned an error
530-prima_module.c:Globus Gridmap Callout:430:
530-Gridmap lookup failure: Could not retrieve mapping for
/DC=org/DC=doegrids/OU=People/CN=Andrew Jamieson 732984 from
identity mapping server
530-
530 End.]
RGI_File_sh failed
END_FAILURE thread=0-1-2-0 tr=RGI_File_sh
Swift finished - workflow had errors
