[Swift-devel] Re: Grid Identity Mapping
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Oct 12 14:33:28 CDT 2007
http://www.ci.uchicago.edu/wiki/bin/view/Teraport/UserSupport#Updating_Grid_or_SSH_Credentials
On Fri, 2007-10-12 at 14:31 -0500, andrewj at uchicago.edu wrote:
> Hello folks,
>   I think I need to be mapped or whatever it is called to
> Teraport.
> Is this true?
> Thanks,
> Andrew
> See below.
> Execution failed:
>         Could not initialize shared directory on teraport
> Caused by:
> org.globus.cog.abstraction.impl.file.FileResourceException:
> Error communicating with the GridFTP server
> Caused by:
>         Server refused performing the request. Custom message:
> Bad password. (error code 1) [Nested exception message:
> Custom message: Unexpected reply: 530-Login incorrect. :
> gridmap.c:globus_gss_assist_map_and_authorize:1910:
> 530-Error invoking callout
> 530-globus_callout.c:globus_callout_handle_call_type:727:
> 530-The callout returned an error
> 530-prima_module.c:Globus Gridmap Callout:430:
> 530-Gridmap lookup failure: Could not retrieve mapping for
> /DC=org/DC=doegrids/OU=People/CN=Andrew Jamieson 732984 from
> identity mapping server
> 530-
> 530 End.]
> RGI_File_sh failed
> END_FAILURE thread=0-1-2-0 tr=RGI_File_sh
> Swift finished - workflow had errors
