[Swift-devel] Re: Swift Error! Round 2
Ben Clifford
benc at hawaga.org.uk
Fri Oct 12 03:12:12 CDT 2007
On Wed, 10 Oct 2007, Ben Clifford wrote:
> > If this causes the function to hang, I'd like to try to isolate this into a
> > simple test case.
> > Is the reason obvious to you?
Here is a program that does the same:
type file;
file a <"foo">;
file b <"bar">;
a = b;
> You've got stuff put in one place - a file, mapped by the mapper assigned
> to the feature variable.
> Then you use = to 'assign' that to another place - a different file,
> mapped by the mapper assigned to the array.
> What does that mean? make a copy of the file? Its not defined in the
> present implementation.
