[Swift-devel] Re: Swift Error! Round 2
Ben Clifford
benc at hawaga.org.uk
Wed Oct 10 18:50:56 CDT 2007
On Wed, 10 Oct 2007, Michael Wilde wrote:
> If this causes the function to hang, I'd like to try to isolate this into a
> simple test case.
> Is the reason obvious to you?
You've got stuff put in one place - a file, mapped by the mapper assigned
to the feature variable.
Then you use = to 'assign' that to another place - a different file,
mapped by the mapper assigned to the array.
What does that mean? make a copy of the file? Its not defined in the
present implementation.
Two options: one is properly prohibit this usage of = and give a proper
error message; another is to copy the RHS file to the LHS. But that's
probably messy in the case of more elaborate structures than single files.
> Is it possible to apply a mapper to the entire array fs[] to specify a
> specific pattern for the names of the output files that are placed in
> it?
There is a mapper assigned to the entire array - its implicit because it
isn't specified in the SwiftScript source, and will give filenames that
have a particular base name and also the array index of the relevant array
element. You can attach whatever mapper you want, though for the behaviour
of spreading files between multiple directories, none of the default
mappers will do.
