[Swift-devel] MolDyn at Purdue
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu May 10 12:39:28 CDT 2007
So I made the modifications to the code that generates the GRAM RSL to
take a command line arguement -project ..., which then is simply passed
to the RSL file as <project> ... </project>.  At the moment, this is
something that needs to be set in Falkon at startup, and all resources
provisioned by Falkon will use the same project.   For now I think we
have a solution that works at the various TG sites, and it is not
tightly integrated with Swift.
The issue is much more complex if you want Swift to carry the project
information on a per job basis, and charge it to a (potentially)
different project each job.
Ioan
Ben Clifford wrote:
> not sure whether you're looking to make this code more closely integrated
> with swift and/or a product rather than a research project, but you might
> make the below submission use profile information from the site catalog
> (and transformation catalog?) - it doesn't look like you're doing anything
> fancy in the submission.
> On Wed, 9 May 2007, Ioan Raicu wrote:
>> Hmmm... I don't know.  If you know what modifications we need to make to the
>> GRAM4 RSL to include the specific project, we can simply modify the RSL by
>> changing the create function to add the extra info into the RSL... its a minor
>> change, but we'd have to recompile the DRP stuff again.  If we can't add it to
>> the RSL, then I don't know any other place to put this.  Anyone have any
>> ideas?  I am using the GRAM4 Java API directly in the DRP code.
>> Ioan
>> PS: Here is a sample RSL...
>> iraicu at tg-viz-login1:~/java/Falkon_v0.8/worker> cat
>> RSL.0.0.ia32-compute.1.120.14898358.xml
>> <job>
>>    <executable>/home/iraicu/java/Falkon_v0.8/worker/run.worker.sh</executable>
>>    <directory>/home/iraicu/java/Falkon_v0.8/worker</directory>
>>    <argument>6900000</argument>
>>    <argument>1500000</argument>
>>    <maxWallTime>120</maxWallTime>
>>    <extensions>
>>         <resourceAllocationGroup>
>>            <hostType>ia32-compute</hostType>
>>            <hostCount>1</hostCount>
>>            <cpuCount>1</cpuCount>
>>            <processCount>1</processCount>
>>         </resourceAllocationGroup>
>>     </extensions>
>> </job>
>> My guess is that we could add something like
>> but I am not sure...
>> If no one knows how to do this off the top of their heads, I'll look it up!
>> Veronika Nefedova wrote:
>>> Hi, Ioan:
>>> How do I add my project info into Falcon? (I can't submit anything to PBS
>>> queue unless I specify the project)
>>> Nika
>>> On May 9, 2007, at 12:16 PM, Ben Clifford wrote:
>>>> Do this:
>>>> edit your site catalog to add an entry <profile namespace="globus"
>>>> key="project">TG-STA040020N</profile> for the purdue site, add an entry
>>>> key="project">TG-WHATEVERYOURGRANTNUMBERIS</profile>
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070510/7abaa011/attachment.html>
