[Swift-devel] remote file/directory stuff (bug 22)
Mihael Hategan
hategan at mcs.anl.gov
Fri May 4 09:17:19 CDT 2007
On Fri, 2007-05-04 at 13:38 +0000, Ben Clifford wrote:
> On Tue, 27 Feb 2007, Mihael Hategan wrote:
> > If you can make this translate into something like vdl:(in|
> > out)appmapping(var, path, dest), preferably after the stagein/stageout
> > directives, I can probably make it work.
> I have a patch that (at least for input files) makes this:
> type file;
> (file o) cat(file f) {
> app {
> cat "in.txt" stdout=@o;
> f < "in.txt";
Shouldn't that be f > "in.txt" and perhaps before "cat"? In a strict
language style, that would vaguely suggest "dump f into 'in.txt'" before
running cat...
> file a <"hello.txt">;
> file b <"output.txt">;
> b=cat(a);
> turn into this kml (fragment):
> <vdl:execute>
> <vdl:tr>cat</vdl:tr>
> <vdl:stagein var="{f}"/>
> <vdl:stageout var="{o}"/>
> <vdl:arguments>
> <string>in.txt</string>
> </vdl:arguments>
> <vdl:stdout>
> <vdl:filename>
> <vdl:getfield path=""><variable>o</variable></vdl:getfield>
> </vdl:filename>
> </vdl:stdout>
> <vdl:inappmapping>
> <variable>f</variable>
> <string></string>
> <string>"in.txt"</string>
> </vdl:inappmapping>
> </vdl:execute>
> However, I have no implementation of the <vdl:inappmapping> element. I
> guess its time for me to poke round at the guts of vdl.k a bit more.
1. Using attributes instead of sub-elements may be a little faster.
2. I think the best deal would be to perhaps extend stagein with having
pairs of [localName, remoteName] and deal with that appropriately.
