[Swift-devel] remote file/directory stuff (bug 22)
Ben Clifford
benc at hawaga.org.uk
Fri May 4 08:38:10 CDT 2007
On Tue, 27 Feb 2007, Mihael Hategan wrote:
> If you can make this translate into something like vdl:(in|
> out)appmapping(var, path, dest), preferably after the stagein/stageout
> directives, I can probably make it work.
I have a patch that (at least for input files) makes this:
type file;
(file o) cat(file f) {
app {
cat "in.txt" stdout=@o;
f < "in.txt";
file a <"hello.txt">;
file b <"output.txt">;
b=cat(a);
turn into this kml (fragment):
<vdl:execute>
<vdl:tr>cat</vdl:tr>
<vdl:stagein var="{f}"/>
<vdl:stageout var="{o}"/>
<vdl:arguments>
<string>in.txt</string>
</vdl:arguments>
<vdl:stdout>
<vdl:filename>
<vdl:getfield path=""><variable>o</variable></vdl:getfield>
</vdl:filename>
</vdl:stdout>
<vdl:inappmapping>
<variable>f</variable>
<string></string>
<string>"in.txt"</string>
</vdl:inappmapping>
</vdl:execute>
However, I have no implementation of the <vdl:inappmapping> element. I
guess its time for me to poke round at the guts of vdl.k a bit more.
