[Swift-devel] Fwd: Re: chained genU workflow
Ben Clifford
benc at hawaga.org.uk
Tue May 1 17:06:57 CDT 2007
whats a project profile entry?
On Tue, 1 May 2007, Mihael Hategan wrote:
> This is the list of things I got from them OOB:
> - MPI jobs with the PBS provider. They need to be able to run with more
> than one version of MPI.
> - Easier configuration of tc.data/sites.xml. Basically they need the
> ability to use a global sites.xml while changing only things like the
> project profile entry.
> - The cleanup didn't work as it was. It would submit a job on the
> default execution provider (whatever that was) which needed a project
> profile entry, but the swift library didn't provide one. This was solved
> by hacking the vdl lib and adding /bin/rm in tc.data.
> - They would like the cleanup to be done without pbs in the future
> (possibly fork or directly with the fileop provider). There's some
> thinking that needs to go here.
> That's it I think.
> On Tue, 2007-05-01 at 16:31 -0500, Veronika V. Nefedova wrote:
> > Hi, everybody:
> > I got this email from Xian-He (after i sent him the lqcd workflow) and I do
> > not think I understand what exactly is he talking about.
> > Mihael and/or Yong -- you've worked with this group before I joined - maybe
> > you know what exactly are their problems ? Please give me any background
> > information so I could help them to proceed.
> > Thanks!
> > Nika
> > >Date: Tue, 01 May 2007 16:24:45 -0500
> > >From: Xian-He Sun <sun at iit.edu>
> > >Subject: Re: chained genU workflow
> > >To: "Veronika V. Nefedova" <nefedova at mcs.anl.gov>
> > >Cc: Don Holmgren <djholm at fnal.gov>, simone at fnal.gov,
> > > Nirmal Seenu <nirmal at fnal.gov>, Mike Wilde <wilde at mcs.anl.gov>,
> > > Ian Foster <foster at mcs.anl.gov>
> > >Thank you, Nika. It is a good achievement. Currently, we are still
> > >facing
> > >two technical issues,
> > >1. The lqcd computing environment is not an true Grid environment. We
> > >still
> > >need to modify your code to make it work. We have had some success of
> > >the hello
> > >example and will work on this one too.
> > >2. We have made Swift talking to PBS directly but some efficiency
> > >issues remain
> > >at this time. Some modification at the Swift side is needed. Nirmal is
> > >working with Mihael Hategan on this regard.
> > >Thank you,
> > >Xian-He
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
