[Swift-devel] Fwd: Re: chained genU workflow
Mihael Hategan hategan at mcs.anl.gov
Tue May 1 16:56:42 CDT 2007
This is the list of things I got from them OOB:
- MPI jobs with the PBS provider. They need to be able to run with more
than one version of MPI.
- Easier configuration of tc.data/sites.xml. Basically they need the
ability to use a global sites.xml while changing only things like the
project profile entry.
- The cleanup didn't work as it was. It would submit a job on the
default execution provider (whatever that was) which needed a project
profile entry, but the swift library didn't provide one. This was solved
by hacking the vdl lib and adding /bin/rm in tc.data.
- They would like the cleanup to be done without pbs in the future
(possibly fork or directly with the fileop provider). There's some
thinking that needs to go here.
That's it I think.
On Tue, 2007-05-01 at 16:31 -0500, Veronika V. Nefedova wrote:
> Hi, everybody:
> I got this email from Xian-He (after i sent him the lqcd workflow) and I do
> not think I understand what exactly is he talking about.
> Mihael and/or Yong -- you've worked with this group before I joined - maybe
> you know what exactly are their problems ? Please give me any background
> information so I could help them to proceed.
> Thanks!
> Nika
> >Date: Tue, 01 May 2007 16:24:45 -0500
> >From: Xian-He Sun <sun at iit.edu>
> >Subject: Re: chained genU workflow
> >To: "Veronika  V. Nefedova" <nefedova at mcs.anl.gov>
> >Cc: Don Holmgren <djholm at fnal.gov>, simone at fnal.gov,
> >    Nirmal Seenu <nirmal at fnal.gov>, Mike Wilde <wilde at mcs.anl.gov>,
> >    Ian Foster <foster at mcs.anl.gov>
> >Thank you, Nika. It is a good achievement. Currently, we are still
> >facing
> >two technical issues,
> >1. The lqcd computing environment is not an true Grid environment. We
> >still
> >need to modify your code to make it work. We have had some success of
> >the hello
> >example and will work on this one too.
> >2. We have made Swift talking to PBS directly but some efficiency
> >issues remain
> >at this time. Some modification at the Swift side is needed. Nirmal is
> >working with Mihael Hategan on this regard.
> >Thank you,
> >Xian-He
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
