[Swift-devel] swift errors
Yong Zhao yongzh at cs.uchicago.edu
Wed Mar 21 10:23:28 CDT 2007
Yes the first line:
OPTIONS=
replace it with
OPTIONS="-Xms512m -Xmx512m"
Yong.
On Wed, 21 Mar 2007, Veronika  V. Nefedova wrote:
> Hi, Yong,
> I found these OPTIONS entries in swift exec file:
> [59] wiggum /sandbox/nefedova/SWIFT/vdsk-0.1rc2/bin > grep OPTIONS swift
> OPTIONS=
>          OPTIONS="$OPTIONS -D$2=$1"
> OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
>      eval java ${OPTIONS} ${COG_OPTS} ${EXEC} ${CMDLINE}
>      eval java ${OPTIONS} ${COG_OPTS} -classpath ${LOCALCLASSPATH} ${EXEC}
> ${CMDLINE}
> Which one should be modified to increase the heap size ( I assume the first
> one? -- just want to be sure).
> Thanks,
> Nika
> At 10:31 AM 3/18/2007, Yong Zhao wrote:
> >Hi Nika,
> >The socket error is fine, it is due to some unsolved issue in the
> >java GridFTP client, you can ignore that.
> >For the memory, you need to set the memory option for JVM a bit larger,
> >locate the execute swift in you swift_home/bin, and edit the OPTIONS
> >Yong.
> >On Sun, 18 Mar 2007, Veronika  V. Nefedova wrote:
> > > HI,
> > > When I  was running the same workflow that worked before without any errors
> > > - I got this errors on my stdout:
> > > Exception occured in the exception handling code, so it cannot be properly
> > > propagated to the user
> > > java.lang.IllegalArgumentException: This socket does not seem to exist in
> > > the socket pool.
> > >          at org.globus.ftp.dc.SocketPool.remove(SocketPool.java:78)
> > >          at
> > org.globus.ftp.dc.GridFTPTransferSinkThread.shutdown(GridFTPTransferSinkThread.java:87)
> > >          at
> > > org.globus.ftp.dc.TransferSinkThread.run(TransferSinkThread.java:78)
> > > <a lot of these>
> > > And then these (also a lot of them):
> > > java.lang.OutOfMemoryErrorjava.lang.OutOfMemoryError
> > > The is on wiggum in
> > > /sandbox/ydeng/alamines/swift-MolDyn-free-final-lor82qgcceac0.log and I am
> > > suing this swift code/verison: /sandbox/nefedova/SWIFT/vdsk-0.1rc2/
> > > Nika
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
