[Swift-devel] swift errors
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Wed Mar 21 10:14:17 CDT 2007
Hi, Yong,
I found these OPTIONS entries in swift exec file:
[59] wiggum /sandbox/nefedova/SWIFT/vdsk-0.1rc2/bin > grep OPTIONS swift
OPTIONS=
         OPTIONS="$OPTIONS -D$2=$1"
OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
     eval java ${OPTIONS} ${COG_OPTS} ${EXEC} ${CMDLINE}
     eval java ${OPTIONS} ${COG_OPTS} -classpath ${LOCALCLASSPATH} ${EXEC}
${CMDLINE}
Which one should be modified to increase the heap size ( I assume the first
one? -- just want to be sure).
Nika
At 10:31 AM 3/18/2007, Yong Zhao wrote:
>Hi Nika,
>The socket error is fine, it is due to some unsolved issue in the
>java GridFTP client, you can ignore that.
>For the memory, you need to set the memory option for JVM a bit larger,
>locate the execute swift in you swift_home/bin, and edit the OPTIONS
>OPTIONS="-Xms512m -Xmx512m"
>Yong.
>On Sun, 18 Mar 2007, Veronika  V. Nefedova wrote:
> > HI,
> > When I  was running the same workflow that worked before without any errors
> > - I got this errors on my stdout:
> > Exception occured in the exception handling code, so it cannot be properly
> > propagated to the user
> > java.lang.IllegalArgumentException: This socket does not seem to exist in
> > the socket pool.
> >          at org.globus.ftp.dc.SocketPool.remove(SocketPool.java:78)
> >          at
> org.globus.ftp.dc.GridFTPTransferSinkThread.shutdown(GridFTPTransferSinkThread.java:87)
> >          at
> > org.globus.ftp.dc.TransferSinkThread.run(TransferSinkThread.java:78)
> > <a lot of these>
> > And then these (also a lot of them):
> > java.lang.OutOfMemoryErrorjava.lang.OutOfMemoryError
> > The is on wiggum in
> > /sandbox/ydeng/alamines/swift-MolDyn-free-final-lor82qgcceac0.log and I am
> > suing this swift code/verison: /sandbox/nefedova/SWIFT/vdsk-0.1rc2/
> > Nika
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
