[Swift-devel] swift errors
Veronika V. Nefedova nefedova at mcs.anl.gov
Wed Mar 21 10:27:59 CDT 2007
Thanks, Yong!
Nika
At 10:23 AM 3/21/2007, Yong Zhao wrote:
>Yes the first line:
>OPTIONS=
>replace it with
>OPTIONS="-Xms512m -Xmx512m"
>Yong.
>On Wed, 21 Mar 2007, Veronika  V. Nefedova wrote:
> > Hi, Yong,
> > I found these OPTIONS entries in swift exec file:
> > [59] wiggum /sandbox/nefedova/SWIFT/vdsk-0.1rc2/bin > grep OPTIONS swift
> > OPTIONS=
> >          OPTIONS="$OPTIONS -D$2=$1"
> > OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
> >      eval java ${OPTIONS} ${COG_OPTS} ${EXEC} ${CMDLINE}
> >      eval java ${OPTIONS} ${COG_OPTS} -classpath ${LOCALCLASSPATH} ${EXEC}
> > ${CMDLINE}
> > Which one should be modified to increase the heap size ( I assume the first
> > one? -- just want to be sure).
> > Thanks,
> > Nika
> > At 10:31 AM 3/18/2007, Yong Zhao wrote:
> > >Hi Nika,
> > >The socket error is fine, it is due to some unsolved issue in the
> > >java GridFTP client, you can ignore that.
> > >For the memory, you need to set the memory option for JVM a bit larger,
> > >locate the execute swift in you swift_home/bin, and edit the OPTIONS
> > >Yong.
> > >On Sun, 18 Mar 2007, Veronika  V. Nefedova wrote:
> > > > HI,
> > > > When I  was running the same workflow that worked before without
> any errors
> > > > - I got this errors on my stdout:
> > > > Exception occured in the exception handling code, so it cannot be
> properly
> > > > propagated to the user
> > > > java.lang.IllegalArgumentException: This socket does not seem to
> exist in
> > > > the socket pool.
> > > >          at org.globus.ftp.dc.SocketPool.remove(SocketPool.java:78)
> > > >          at
> org.globus.ftp.dc.GridFTPTransferSinkThread.shutdown(GridFTPTransferSinkThread.java:87)
> > > >          at
> > > > org.globus.ftp.dc.TransferSinkThread.run(TransferSinkThread.java:78)
> > > > <a lot of these>
> > > > And then these (also a lot of them):
> > > > java.lang.OutOfMemoryErrorjava.lang.OutOfMemoryError
> > > > The is on wiggum in
> > > > /sandbox/ydeng/alamines/swift-MolDyn-free-final-lor82qgcceac0.log
> and I am
> > > > suing this swift code/verison: /sandbox/nefedova/SWIFT/vdsk-0.1rc2/
> > > > Nika
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
