[Swift-devel] Re: [Swft] Q about throttling
    Ben Clifford
    benc at hawaga.org.uk
    Thu Jun 21 11:07:32 CDT 2007
neat. when was the run made that generated those graphs?
The submits seem to be going through at about 1/sec in the 1000..2000s
time range. Is that the bit that is the problem?
On Thu, 21 Jun 2007, Ian Foster wrote:
> See this document for a set of three graphs that Ioan produced:
> http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/100-Mol_MolDyn.pdf
> The first is the same as Tibi's, I think. The second and third are new. I want
> to have all three produced in a standard way for every application run.
> Ian.
> Ben Clifford wrote:
> > actually, the graph that Tibi showed, which I think is pretty much the same
> > as the graph from Ioan's gui visualizer thing, would be interesting to see
> > for the present MolDyn runs.
> > It was interesting to look at when wondering about the bug Yong fixed last
> > week.
> > > agreed
> > > > > I'm gathering from this exchange that this is not possible?
> > > > I have no idea. It doesn't seem to be documented.
> > > > But the number one rule of tech support is don't take somebody else's
> > > > partially solved problem. It would be good to see what is actually
> > > > causing
> > > > you to suspect that there's a throttling problem.
