[Swift-devel] Re: [Swft] Q about throttling
    Ian Foster
    foster at mcs.anl.gov
    Thu Jun 21 10:57:56 CDT 2007
See this document for a set of three graphs that Ioan produced:
http://people.cs.uchicago.edu/~iraicu/research/docs/MolDyn/100-Mol_MolDyn.pdf
The first is the same as Tibi's, I think. The second and third are new.
I want to have all three produced in a standard way for every
application run.
Ian.
Ben Clifford wrote:
> actually, the graph that Tibi showed, which I think is pretty much the
> same as the graph from Ioan's gui visualizer thing, would be interesting
> to see for the present MolDyn runs.
> It was interesting to look at when wondering about the bug Yong fixed last
> week.
> On Thu, 21 Jun 2007, Ian Foster wrote:
>> agreed
>>>> I'm gathering from this exchange that this is not possible?
>>> I have no idea. It doesn't seem to be documented.
>>> But the number one rule of tech support is don't take somebody else's
>>> partially solved problem. It would be good to see what is actually causing
>>> you to suspect that there's a throttling problem.
   Ian Foster, Director, Computation Institute
Argonne National Laboratory & University of Chicago
Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
      Globus Alliance: www.globus.org.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070621/0a645582/attachment.html>
