[Swift-devel] CPU usage with provider-deef
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jun 16 10:02:46 CDT 2007
Yourkit (www.yourkit.com) has free licenses for open source projects for
their profiler. Point them to a globus web page that has your name, and
they'll send you the license. Alternatively, there are other profilers
out there, and I strongly recommend using them on such issues.
Mihael
On Sat, 2007-06-16 at 10:00 -0500, Ioan Raicu wrote:
> Nope, I think this is a different problem, or at least a subset of the
> problems we were having before.
> Since we fixed the CPU utilization, and we moved to a bigger box (4
> CPUs with 2GB of memory), everything is happening in a timely fashion
> (a few ms per notification delivery throughout the experiment).  Plus,
> I believe the view is consistent (the same tasks look complete on both
> ends) between Falkon and Swift, but we are still checking on this as
> the run was made just last night for the 100 mol run.  We'll keep you
> posted with what we find.
> Ioan
> Ben Clifford wrote:
> > On Sat, 16 Jun 2007, Ioan Raicu wrote:
> > > having problems with the 100 molecule run in MolDyn.  Its not clear where the
> > > problem is, on the surface Falkon looks fine... we are looking into where
> > > everything breaks to cause Swift to not continue with the workflow to
> > > completion!
> > The same problem that you showed me the other day or different?
> > with 'the same problem' being that falkon thinks all the jobs are done;
> > but that falkon's measure response time for sending completion
> > notifications gets approximately linearly longer over time and the swift
> > JVM uses ~100% and doesn't inidicate job completion at all after a certain
> > period.
> > or different symptoms now?
> Ioan Raicu
> Ph.D. Student
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
>        http://dsl.cs.uchicago.edu/
