[Swift-devel] CPU usage with provider-deef
    Ian Foster
    foster at mcs.anl.gov
    Sat Jun 16 10:59:17 CDT 2007
It seems important that Ioan sit down with Mihael and work through the
Falkon code to see where it can be simplified, improved, etc. I am sure
that this will result in problems being identified and fixed that will
otherwise cost us time later.
Mihael Hategan wrote:
> Yourkit (www.yourkit.com) has free licenses for open source projects for
> their profiler. Point them to a globus web page that has your name, and
> they'll send you the license. Alternatively, there are other profilers
> out there, and I strongly recommend using them on such issues.
> Mihael
> On Sat, 2007-06-16 at 10:00 -0500, Ioan Raicu wrote:
>> Nope, I think this is a different problem, or at least a subset of the
>> problems we were having before.
>> Since we fixed the CPU utilization, and we moved to a bigger box (4
>> CPUs with 2GB of memory), everything is happening in a timely fashion
>> (a few ms per notification delivery throughout the experiment).  Plus,
>> I believe the view is consistent (the same tasks look complete on both
>> ends) between Falkon and Swift, but we are still checking on this as
>> the run was made just last night for the 100 mol run.  We'll keep you
>> posted with what we find.
>> Ioan
>> Ben Clifford wrote:
>>> On Sat, 16 Jun 2007, Ioan Raicu wrote:
>>>> having problems with the 100 molecule run in MolDyn.  Its not clear where the
>>>> problem is, on the surface Falkon looks fine... we are looking into where
>>>> everything breaks to cause Swift to not continue with the workflow to
>>>> completion!
>>> The same problem that you showed me the other day or different?
>>> with 'the same problem' being that falkon thinks all the jobs are done;
>>> but that falkon's measure response time for sending completion
>>> notifications gets approximately linearly longer over time and the swift
>>> JVM uses ~100% and doesn't inidicate job completion at all after a certain
>>> period.
>>> or different symptoms now?
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>        http://dsl.cs.uchicago.edu/
   Ian Foster, Director, Computation Institute
Argonne National Laboratory & University of Chicago
Argonne: MCS/221, 9700 S. Cass Ave, Argonne, IL 60439
Chicago: Rm 405, 5640 S. Ellis Ave, Chicago, IL 60637
Tel: +1 630 252 4619.  Web: www.ci.uchicago.edu.
      Globus Alliance: www.globus.org.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070616/2e6f77a3/attachment.html>
