[Swift-devel] CPU usage with provider-deef
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Jun 15 13:02:58 CDT 2007
Ben,
we tested both my workflow and a simple "sleep" workflow. Both tests
produced 100% CPU usage when ran with Falcon. When submitted directly
to GRAM from swift - only a fraction of 1% CPU was used. I know that
Yong did some additional testings, but I do not know the results.
Nika
On Jun 15, 2007, at 11:48 AM, Ben Clifford wrote:
> Yesterday, I was playing a bit with Ioan and Nika - they submitted
> a 68
> node / 15 minute workflow through provider-deef & falkon and saw
> the swift
> JVM on the submit node using about 100% CPU; then the same workflow
> running through the GT2 GRAM provider rather than provider-deef and
> falkon
> appeared to use significantly less.
> I wandered off at that point so don't know if any interesting
> results came
> after.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
