[Swift-devel] CPU usage with provider-deef
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jun 15 11:48:01 CDT 2007
Yesterday, I was playing a bit with Ioan and Nika - they submitted a 68
node / 15 minute workflow through provider-deef & falkon and saw the swift
JVM on the submit node using about 100% CPU; then the same workflow
running through the GT2 GRAM provider rather than provider-deef and falkon
appeared to use significantly less.
I wandered off at that point so don't know if any interesting results came
after.
